Re: Farmall Super M
Posted by Andy Martin on June 12, 2006 at 14:23:23 from (64.219.39.195):
In Reply to: Re: Farmall Super M posted by Tom O on June 12, 2006 at 12:30:06:
Well, it can.
But take the drain off the carburetor and see how much gas comes out for a couple of minutes. You may have something floating around in the fuel tank which is plugging the opening. Or the gasket may be off the shutoff valve partially plugging the fuel flow. That one was tough to find. If the fuel flows good until the bowl is empty then slows dramatically you probably have a restriction.
