Re: Replacing pulley on h water pump
Posted by Haas on June 12, 2006 at 18:21:25 from (12.65.48.88):
In Reply to: Replacing pulley on h water pump posted by RMO/MN on June 12, 2006 at 06:35:43:
I did this a few months back on a Super H. H would be the same. No need to take off the front bolster. You will need to remove the radiator which means removing the steering shaft because it goes through the radiator. The adjustable flange on the H comes off the back side of the assembly, which means you have to take the bearing assembly off to get at it. Since you have do do this, replace the grease seals while you have the opportunity. Also get a ring or two of pump packing to add under the packing nut. You have to remove the water pump driver set up that is in front of the fan, and then the fan and the packing nut and the bearing assembly retainer nut. then you can slide the bearing assembly and the pulley off the water pump body. The back side of the pulley is pressed on and retained by a 1/8 diameter pin through it. I found the pin easy to drive out, but need a press to get the back side off. Lining things up to get the pin back in was not so easy. Had to try it twice. Second time at machine shop. Use a piece of 1/8 rod through the hole in the flange so you can see where to position the flange(scribe some marks) to align the holes when you press it back on. On mine the hole was not perpendicular to anything, so with out something to go buy couldn't get things lined up.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
