Re: SUPER A trans parts
Posted by Roger46 on June 12, 2006 at 19:16:55 from (69.58.143.103):
In Reply to: SUPER A trans parts posted by flem on June 12, 2006 at 07:30:40:
There are a lot of those aluminum oil slinger gears with the teeth sheared off. My theory is that the transmission gets water in it and the aluminum gears gets frozen in the water. When you start the tractor, the gear can't turn so the aluminum teeth shear off. The steel gears are able to break the ice and turn it to slush. My B had all the teeth off that gear. I suspect that after the initial teeth are sheared off that the others eventually get sheared off to as they catch and try to mesh. Roger
