Re: farmall H not getting gas to plugs
Posted by Rich Griffin on June 13, 2006 at 19:03:33 from (69.66.98.60):
In Reply to: farmall H not getting gas to plugs posted by F250 on June 13, 2006 at 18:52:33:
How is your compression? Could have bad manifold gaskets. If this has been setting for a while the cyl walls coulld be dry. Remove spark plugs and squirt a fair amount of oil into each cyl and crank over and let set for a while. This will build up compressin and vacume. Or you could have a few valves stuck open. Maybe the needle in the carb is sticking shut. Could be anything. Hope this helps
Today's Featured Article - A Belt Pulley? Really Doing Something? - by Chris Pratt. Belt Pulleys! Most of us conjure up a picture of a massive thresher with a wide belt lazily arching to a tractor 35 feet away throwing a cloud of dust, straw and grain, and while nostalgic, not too practical a method of using our tractors. While this may have been the bread and butter of the belt work in the past (since this is what made the money on many farms), the smaller tasks may have been and still can be its real claim to fame. The thresher would bring in the harvest (and income) once a y ... [Read Article]
