Re: Gene Bender/Help Question
Posted by gene bender on June 14, 2006 at 02:33:00 from (66.43.221.78):
In Reply to: Gene Bender/Help Question posted by Retired 05 in VA on June 13, 2006 at 08:37:19:
I have never ran into that yet but if the leak doesevt seem to be a pressure leak clean area good and use JB WELD. Like other post says drill and tap a cap screw would work probably the best. Welding could also be another way. You would need to remove the unit from the tractor.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
