Re: Gene B or Hugh........
Posted by gene bender on June 14, 2006 at 02:39:34 from (66.43.221.78):
In Reply to: Gene B or Hugh........ posted by scotty on June 13, 2006 at 06:52:00:
Yes the rear mounts were different from SA to A which means when mounting the imps you would have to make corrections but the important thing is the distance from side to side is the same. But you must remember the hy rockshaft on the SA means you would also have to change lifting devices for the implement.
