Re: 300 battery short
Posted by El Toro on June 14, 2006 at 05:33:47 from (64.12.114.24):
In Reply to: 300 battery short posted by IaGary on June 14, 2006 at 04:23:42:
I would hook a battery charger to the battery and see if it will charge. Even if the alternator was damaged, the tractor should start with a fully charged battery. Once you have a fully charged battery check for battery voltage at your coil with the ignition switch on. If the tractor starts hook your volt meter leads across the battery terminals and run the engine at 3/4 throttle. Should have around 7.5 volts. Most auto machine shops can repair your alternator if it doesn't charge. Hal
PS: Here's a web site for 6 volt alternators.
http://www.alternatorparts.com/6_volt_alternators_&_kits.htm
