Re: 300 battery short
Posted by Bob M on June 14, 2006 at 06:49:50 from (151.190.254.108):
In Reply to: 300 battery short posted by IaGary on June 14, 2006 at 04:23:42:
There’s certainly a chance the short at the battery toasted the alternator. However the engine should still start/run even if the alternator is bad. What I suspect happened is the brief short damaged the wiring somewhere between the starter switch, ammeter and ignition switch First thing I'd do disconnect/tape the wire a the BAT terminal on the regulator (in case the alternator has suffered from shorted diode or something). Then charge the battery and try starting the tractor. If it still won't fire turn the ignition on and check for voltage at the ignition side of the coil primary (the side NOT connected to the distributor). If voltage is present the tractor should run - the "no fire" problem is elsewhere. However if no voltage is seen, you’ve got to find/repair a break in the wiring to the coil. Good luck!
Home
| Forums
Today's Featured Article -
The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
