Re: 12 Volt Conversion Resistor
Posted by John T on June 15, 2006 at 06:40:21 from (66.244.90.5):
In Reply to: 12 Volt Conversion Resistor posted by Duane WI on June 15, 2006 at 05:48:55:
Duane, a typical rating for a conventional straight (NOT a heat sensitive variable resistance Thermistor) Ignition Ballast Resistor is around 1.5 to 1.85 ohms. Ideally, to serve as a pure 50/50 static voltage divider to drop 12.6 battery volts in half leaving 6.3 across the coil, it would be somewhere near the same ohms as the coils primary (measured between its lil + and - terminals). The thing youre wanting to do to prevent premature burning up of the points and not overheat the coil is to limit the coil/points current to around 4 amps or so, which at 12 volts requires around 3+ ohms of TOTAL (coil + Ballast) resistance in the ignition primary circuit. With that alternator, the battery voltage may run a lil higher then using a genny, so a lil over 3 ohms TOTAL (coil + ballast) ignition primary resistance is what I would use to extend point life and not run the coil too warm....... The correct answer to your question really requires you know the coils primary resistance, but this ought to get you in the ball park and the spark should still be sufficient if you err slightly on the safer (more ballast) less current side of these suggestions. If this info is correct ?? (copied it somewhere from a YT Mag post) NAPA # ICR-13 or Standard Ignition # RU-10 are rated @ about 1.77 Ohms to 1.87 Ohms Other sources are Tractor Supply or Rural King etc. Wire it in series ahead of the coil after the ignition switch and youre good to go. The alternative would be to buy a full 12 volt rated (internally ballasted) coil that requires no external ballast but the ballast is cheaper. John T
Home
| Forums
Today's Featured Article -
Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
