Re: Super M trougle
Posted by Janicholson on June 15, 2006 at 14:00:33 from (199.17.6.122):
In Reply to: Super M trougle posted by Tom O on June 15, 2006 at 13:15:02:
You do not say coil in your description of replaced parts. Choking it might make the spark jump a little easier if the coil was getting hot and breaking down.
A cracked manifold that warps when hot wolud leak air in when hot allowing lean conditions.
Distributor advance malfunction could cause missing when hot, check advance mechanism (under points)
JimN
