Re: Farmall 300 TA
Posted by Ksfarmmer on June 15, 2006 at 16:46:32 from (24.255.226.14):
In Reply to: Farmall 300 TA posted by IHNewbee on June 15, 2006 at 16:25:51:
My 300 Farmall has the T/A on the left side (while sitting on the tractor). Pull the lever back (towards you while sitting) to engage the low side. There should be a release lever that allows you to let the lever foward and dis-engage the torque amplifier. The levers on the right side, one or two on the upper right are for the front and rear hydraulics and/or the fast hitch. The third lever on the right will be a much longer lever that when pulled back engages the PTO. It will have a push button release to disengage the PTO by releasing and pushing the lever back foward. If you have some load on the tractor such as a slight incline and the tractor does not slow down the the T/A is probably not functioning. Apparently a somewhat common problem. Others can probably tell what's involved to fix it.
