Re: H spun bearing
Posted by El Toro on June 16, 2006 at 03:44:02 from (205.188.116.133):
In Reply to: Re: H spun bearing posted by KansasBri on June 15, 2006 at 15:44:06:
You can buy a sleeve and piston kit from this forum for about $350.00. You could check with your local auto machine shop on the cost of any machining. Crankshaft if it needs to be ground,
valve job, cam bearings and degreasing block. They can supply all your rod and main bearings too. They should install your new pistons to the old rods and you probably need new bushings
in the old rods. Very easy to put $1000.00 or more in these engines. Hal
