Re: M Flywheel Swap
Posted by Turbos10 on June 16, 2006 at 03:56:23 from (67.76.48.106):
In Reply to: Re: M Flywheel Swap posted by tom Windsor on June 15, 2006 at 05:02:27:
The current flywheel is a stock cast iron piece. The problem is that they are very heavy, not balanced, and only held by three bolts. The basically means they are prone to break the center out and come loose from the crankshaft. That that point they can also cut the tractor in half which poses some obvious problems :).
