Re: farmall b wont run after bad rain storm.
Posted by El Toro on June 16, 2006 at 05:10:45 from (64.12.116.65):
In Reply to: Re: farmall b wont run after bad rain storm. posted by RVaughn on June 15, 2006 at 12:03:36:
You need to remove No1 sparkplug near the radiator and bring No1 piston up to TDC on the compression stroke. You need to locate the timing mark on the flywheel and chalk it so it will be easy to see. Then have someone hand crank the engine while you hold your thumb over the plug hole. When you feel pressure against your thumb, stop turning the engine and look for your chalk mark. Once you locate the timing mark resume cranking the engine until mark is aligned. Remove the cap and see where your rotor is pointing should be at the No1 plug tower. If you had noticed where the rotor was prior to pulling the mag all you had to do was turn the rotor to that position and reinstall the mag. If the rotor is off you need to pull the mag and turn the rotor to No1 plug tower and reinstall mag. The point setting on a mag is .013" for all IH mags. Make sure your plug wires are in the correct firing sequence. 1-3-4-2 Hal
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
