Re: Tired TA Advice
Posted by the tractor vet on June 16, 2006 at 07:38:03 from (64.179.117.192):
In Reply to: Re: Tired TA Advice posted by Allan In NE on June 16, 2006 at 05:54:25:
Allen your problem is either in the MCV pump or ya need a new spring kit in the MCV . Run a pressure check and if ya can have someone flowrate the MCV pump and replacve it i think it is low flow rate on yours and the other guy RUN IT TILL IT DIES .
