Re: 656ta
Posted by Janicholson on June 17, 2006 at 16:39:11 from (66.173.50.68):
In Reply to: 656ta posted by haymaker pat on June 17, 2006 at 15:10:07:
I think your TA clutch is out. (still requires R&R split) I assume it moves and pulls in TA, but does not change speed in direct (lever forward). probably a good idea to change out the master clutch, and the TA ramp/rollers at the least when going in. JimN
  • Re: 656ta haymakerpat 19:38:58 06/18/06 (0)
