Re: Screen in Hydraulic Reservoir - 350 Utility
Posted by Dellbertt on June 17, 2006 at 18:48:16 from (204.39.209.166):
In Reply to: Screen in Hydraulic Reservoir - 350 Utility posted by jmauss on June 17, 2006 at 17:55:21:
As long as you are this far into it make sure you clean out the resevoir real good and you might even clean the lines to the pump because these to lines are the lowest points in the sysem and easy to remove for cleaning.
I dont know of any used ones. you might try stamm equipment in wayland, michigan. dont know the number.
I bought two new ones from IH several years ago and hated every second of it.
Be very careful setting the resevoir top into place.
