Re: Screen in Hydraulic Reservoir - 350 Utility
Posted by Brownie 45 on June 18, 2006 at 04:40:27 from (207.177.82.117):
In Reply to: Screen in Hydraulic Reservoir - 350 Utility posted by jmauss on June 17, 2006 at 17:55:21:
If the screen can be rounded out again, you might try soldering the crack. I think the originals were made of brass, which if cleaned well, can be successfully soldered. If you are taking the lines completely off, I'd just use gas & see what comes out. If they really look bad[ a lot of crud], then you may have to pull something through.
