Re: Front hub on a H
Posted by RMO/MN on June 18, 2006 at 06:57:37 from (64.122.139.56):
In Reply to: Re: Front hub on a H posted by riverbend on June 17, 2006 at 20:28:14:
Thanks for the info. I have a parts book on order but in the mean time I fiquared it must be a loose fit 5/8. I just didn't want to have another hub crack out as the correct one wasn't easy to find.
Bob
