Re: Farmall 230 engine rebuilding questions???
Posted by Red Dave on June 18, 2006 at 08:57:07 from (66.109.236.57):
In Reply to: Farmall 230 engine rebuilding questions??? posted by t.r.y. on June 17, 2006 at 18:07:47:
Take the engine apart. Pull the old sleeves. Measure the inside diameter of the bore at the bottom where the O-ring seal seats against the bottom of the sleeve.
That inside diameter will determine which sleeve sets will fit into your block without machining. Know that mesurment when you order a rebuild kit.
