Re: farmall regular flywheel
Posted by Kevin LA-CA on June 18, 2006 at 09:44:45 from (24.55.82.47):
In Reply to: farmall regular flywheel posted by Glen H on June 18, 2006 at 04:31:26:
Glen
There is a special puller, one could make relatively easily.
However, I used 3 long 3/4" bolts with long threads. I threaded them into the tapped holes in the flywheel. The bolts pushed against the inside of the bell housing. I rotated the flywheel until I found 3 flat spots on the bell housings for the ends to fit. Just slowly & evenly tightened all three and backed the flywheel off.
HTH. kevin
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
