Re: Farmall C dies
Posted by old on June 18, 2006 at 10:41:01 from (4.244.186.24):
In Reply to: Farmall C dies posted by Shannon Moe on June 18, 2006 at 10:30:45:
Is it a mag or a distubutor type system?? If its a distubutor system I would try a hot wire from the battery to make sure the ignition switch isn't going bad. If that doesn't help then try replaceing the condenser. Or it could also be the coil but not as likely. When it dies have you check to make sure you have a good brite blue spark?? If the spark isn't a good blue spark you have found where your problem is, its in the ignition system
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
