Re: Farmall C dies
Posted by CNKS on June 18, 2006 at 11:04:31 from (204.249.178.138):
In Reply to: Farmall C dies posted by Shannon Moe on June 18, 2006 at 10:30:45:
"-It would run well for 10-15 minutes, then die, as though out of fuel, and would not immediately restart -After 10-15 minutes, it would restart and run for a minute or two, then die again" The above is a typical coil problem. After it cools of it will start. "Heres what I did: -rebuilt carb -replaced fuel line/screen/elbow -cleaned strainer assembly -cleaned out tank After this, it would idle fairly well but die under load. Being unsure of my carb rebuilding skill, I then replaced the old carb with a pro rebuild. Now it starts easily and runs well for 5-10 seconds, then dies just as if I had shut it off." This sounds like a fuel delivery problem "pro rebuild" on a carb doesn't mean much. However you could still have crud inside the outlet in the tank. Look inside the tank and carefully run a wire in the outlet. If by "replaced fuel line/screen/elbow", if that was on the sediment bowl, there is another screen inside the fitting on the carb, but my interpretation is that you replaced that. Othewise you have a problem inside the carb. Disassemble, soak in carb cleaner overnight (carb cleaner, not parts cleaner) blow out with compressed air, and set the float to specs. Those carbs are very simple. I am not completely ruling out the coil, but usually the tractor will not restart within 5-15 minutes of dying.
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
