Re: Finish mower on a 200
Posted by BobG in VA on June 18, 2006 at 16:33:37 from (64.12.116.65):
In Reply to: Finish mower on a 200 posted by Heywood on June 18, 2006 at 11:10:01:
I think you'll be fine with a 72" finish mower if your 200 is in good tune. I "assume" you have a 3 pt conversion on your FashHitch.... If your grass is a tad high to start with, put the wheels on the finish mower as high as they will go and go over it. Once you have done this lower your wheels and do it again until you get the height you are looking fore. My bud has a good running SC that he runs a 84" Kioti finish mower at half throttle in 2nd gear and it cuts great (Mind you he's been cutting this grass for years so its well groomed. If you can't get the finish mower wheels high enough to ruff cut the grass, raise the mower some and go over it that way---very slowly as the front end can get very light with a big mower on the back. BobG in VA
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
