Re: M Starter Lever
Posted by CNKS on June 18, 2006 at 19:33:10 from (204.249.178.138):
In Reply to: M Starter Lever posted by Tim Tonjes on June 17, 2006 at 21:00:41:
There was no lever on the M, I think the SM had a lever. One cable runs from the starter switch to the starter. There is a cable from the other starter switch to the negative post on the battery. Positive post on the battery is grounded. Also on the same starter switch terminal that the switch to battery cable attaches to, run a wire to the negative terminal on the ammeter. If you attach this wire to the positive ammeter terminal the engine will die when you release the starter switch. The positive terminal on the ammeter has a wire that runs to the "bat" terminal on the regulator.
