Re: 300u oil drain/fill places
Posted by TDK on June 18, 2006 at 20:33:09 from (205.188.116.133):
In Reply to: 300u oil drain/fill places posted by Jimer on June 18, 2006 at 17:05:43:
Engine oil fill is just in front of hyd. pump. I'm sure that's what you meant. There's 3 drains for trans/diff. One large plug in the lowest point of trans; one in the front area just behind clutch housing & one just behind the "seasonal(pto) disconnect", plug is in horizontal position.Only one fill plug beside gearshift & one check plug on left under floorboard. Draining the hyd. reservoir is easiest by loosening the hyd. line at the reservoir and pump. The drain is actually at the return line from P/S on left side of reservoir. Without P/s this is just a plug. Add at the dipstick hole.
