Re: IH 584 oil pressure specs.
Posted by El Toro on June 19, 2006 at 03:42:43 from (64.12.116.65):
In Reply to: IH 584 oil pressure specs. posted by Stubob on June 18, 2006 at 10:32:53:
After you have installed the new gauge and worked the tractor keep an eye on the gauge and record the max and mininum pressure. When the engine is hot I think 30psi or better is good for wot and it will less at an idle. Hal
