Re: Super M Carb
Posted by RustyFarmall on June 19, 2006 at 08:16:50 from (207.32.13.198):
In Reply to: Super M Carb posted by Tom O on June 19, 2006 at 08:08:10:
Are you sure the carb is causing the problem? If the engine starts, and runs for several minutes, and then shuts down, I would say your problem is somewhere else. Just for the fun of it, completely remove the cap from the gas tank and then start the tractor. If that doesn't do the trick, you may have a restriction in the sediment bowl or fuel line. Send me an e-mail if you want, I'll see if maybe we can figure this thing out.
