Re: Super M Carb
Posted by Sean in Calgary on June 19, 2006 at 11:46:42 from (66.244.207.150):
In Reply to: Super M Carb posted by Tom O on June 19, 2006 at 08:08:10:
Reading this thread, I just had a thought. Although it certainly sounds like an ignition related problem, there might be one other fuel related problem. 1/2 an hour is an AWFUL long time to get to a fuel flow problem, but how long does it take to draw a vacuum in the fuel tank if the vent is plugged? Wtih a gravity fed system like these have, you aren"t getting fuel against a vacuum. Next time it starts to starve, pop the lid off the gas tank and see if it makes a difference. I might be completely off base, but it is certainly a low cost and easily executed troubleshooting step.
If that makes no difference, then I defer to all of the rest of the experience in the forum.
Sean
