Re: Radiator drain issue when installing wide fron
Posted by Cedric on June 20, 2006 at 03:21:55 from (210.55.123.150):
In Reply to: Radiator drain issue when installing wide front on posted by Paul G. in Mn on June 19, 2006 at 16:54:45:
A 45° elbow was screwed onto the existing drain and another piece of pipe screwed into that passing up through the hole in the adapter plate. I found it a a bit tricky getting the thread started when I converted my "H" to wide front.
Sid.
