Re: Farmall C overheating
Posted by Red Dave on June 20, 2006 at 05:11:05 from (24.104.94.34):
In Reply to: Farmall C overheating posted by Vicki Westerhoff on June 19, 2006 at 19:52:25:
I'm with gene on this, those water passages are about the size of a nickel and there are only 4 of them. If you take the bottom water inlet off and shine a light in that lower water chamber, they are in the top of it.
A Super C water pump would bolt right on. All you would need to change is the fan belt and the generator belt. The top (adjustable) mount on the generator would move to the water pump. Super C belts will work as they are just a little longer than the ones you have.
