Farmall Tractors Discussion Board
Re: Farmall Super A Hard Starting
Posted by ltf in nc on January 18, 2000 at 18:42:44 from (206.228.213.204):
In Reply to: Farmall Super A Hard Starting posted by Pipewrench on January 18, 2000 at 16:13:50:
Pipewrench,
If you would answer the questions asked by myself under your previous post I could possibly assist you with your overall problem. I think you tractor is not generating and the coil voltage is weak and when you are cranking during the cold weather the voltage drops even more thus providing an inadequate spark to the plugs. Describe the wiring and component arrangement for your 12 volt conversion in addition to the answers to the previous asked questions. The more information that you can provide will assure that someone will conclude where the problem is and what the solution should be.
Post A Followup
: Re: Re: Farmall Super A Hard Starting
