Re: question on steering/turning
Posted by riverbend on June 20, 2006 at 06:43:27 from (208.160.33.246):
In Reply to: Re: question on steering/turning posted by RonFromCT on June 19, 2006 at 18:15:05:
Check to see that the steering gear arm (the piece that bolts to the bottom of the upper bolster and moves the inner tie rod ends) is not bent. I had the same problem on a C and wound up replacing the arm with a 1/2" plate of aluminum.
