Re: Stan from VA farmall 230 engine??
Posted by Red Dave on June 20, 2006 at 08:04:13 from (24.104.94.34):
In Reply to: Stan from VA farmall 230 engine?? posted by t.r.y. on June 20, 2006 at 03:40:18:
100 psi from 3 1/8 dome-top pistons is not a lot. That's less than the book calls for. If I remember correctly, IH called for 105 psi for stock, 3 inch flat-top pistons. I don't have my book in front of me right now to check for sure.
You can shave some off the head, if it hasn't been planed too much previously. I would get the valves gone over to be sure they seal, maybe have the head machined just until it's flat, then re-assemble it and check compression again.
100 psi isn't real high, but it is enough for the engine to run just fine, and depending on what you want to do with the tractor that may suit your needs.
Today's Featured Article - Antique Tractor Wiring Basics - by Curtis von Fange. One of the most neglected parts of old tractors is the wiring. After sitting in the elements for half a century or more much equipment wiring has deteriorated to sparsely covered strands of copper or other metal. Plastic insulation has cracked, mice have eaten through the older clothed style coverings and the exposed wires have reacted to winter moisture and salts by turning blue and powdery. Terminal ends have corroded, rusted or just plain evaporated away. Aged wires not only keep an engin ... [Read Article]
