Re: Stan from VA farmall 230 engine??
Posted by Stan(VA). on June 21, 2006 at 07:38:44 from (66.82.9.36):
In Reply to: Re: Stan from VA farmall 230 engine?? posted by T.r.y. on June 21, 2006 at 03:13:37:
Can you post a picture of your piston, or any part numbers stamped on them? I looked again and realize that by the time they resized my pictures even smaller than I had them it gets hard to see the dome shapes on the IH pistons (since they were not as shiny as the Tisco). If you need it I could try emailing you one of the pictures directly to get a little better view. The Tisco in the pictures (actually all 3 pistons) are 3-1/8" not 3-1/4". The Tisco is the one you get if you order for a Farmall C with the C-113 engine (3-5/16" lower sleeve OD). The 3-1/4" Tiscos I referenced in my earlier post look totally different. Again, they are ~1/10" shorter on compression height and have a single level, rectangular shaped, raised step on the head that sticks up maybe 1/4". They are the ones you get when you order a kit for the Super C with the C-123 engine (3-7/16" lower sleeve OD). If you have the original block in your 230 (see part numbers in the earlier thread) these won't fit without custom machining and custom O-rings. In the earlier thread you asked about the C-135 sleeves since that motor also has 3-1/4" pistons. I was in a hurry when I posted, but they won't interchange with the C-123(Super C block) because the lower sleeve OD is slightly larger than the 3-7/16", maybe another 1/64" (didn't memorize that one). Don't recall about the pin diameters, seemed like some of the later motors went to a smaller pin but I don't have my books in front of me. I have a spare set of C-135 std altitude firecraters at home and could check but that's a whole 'nuther animal. For the best compression, lowest cost, and easiest overhaul on that block I would recommend the tisco 3-1/8" piston set (just make sure you clean the casting flash/ridges off the top of their pistons to avoid hot spots and detonation). Or if money is no object ;) find a set of 140/240 firecraters. Stan(VA).
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
