Re: Farmall MD fire question
Posted by the tractor vet on June 21, 2006 at 18:52:40 from (64.179.117.145):
In Reply to: Farmall MD fire question posted by Jesse on June 21, 2006 at 18:38:51:
Well now i know that you need the manifold switch as the wire from the ing. switch goes to the manifold then to the dist but i do not know if the mag switch and the one for the dist are the same here . Also you will have to find a dist. from a diesel as they do not have a centrifcal advance in them like the gassers do.
