Re: wd6 carb air-fuel mixture
Posted by KEB on June 22, 2006 at 20:42:16 from (207.94.27.6):
In Reply to: wd6 carb air-fuel mixture posted by tyler cohrs on June 22, 2006 at 19:07:32:
Three things to start with. First, make sure the float level isn't set too low, which will result in not enough gas in the bowl. Also, check the compression release linkage & the cam in the carburetor. If the cam in the fuel bowl isn't adjusted right, it'll hold the needle valve partly closed, resulting in a lack of fuel. Second, just soaking doesn't necessarily clean out all the passages. You need to make sure that you can blow air through all the passages. Aerosol carburetor cleaner is good for checking that passages are clear. Third, make sure you don't have a vacuum leak in the manifold or where the carburetor connects to the mainfold. A vacuum leak after the carburetor will require that the mixture coming out of the carburetor be excessively rick to compensate for the extra air. Drilling the jet would be the last thing I'd do, and I'd make sure I could get a replacement before I touched the original one. These are an oddball carburetor, and I've never tried to buy parts for mine. By the way, my WD-6 requires choke to fire, but then runs fine without choke once its turning over. Keith
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
