If they all line up, I don't see any reason you couldn't use four bolts.
Two would hold one of them, if only because they're there just for the clamping force, and there's nothin' wimpy about a 5/8" bolt. You can also consider that flare at the front end will rest on your front casting or the top of your rail depending where you mount it, and will help support the weight.
As far as the vertical holes at the front, if they'll line up with the vertical holes in the weights and will take a 5/8" NC bolt, no reason you couldn't use them.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
