Farmall Tractors Discussion Board
Re: The Plow Is Identified!!!
Posted by Tim(ny) on January 19, 2000 at 05:36:05 from (165.89.84.250):
In Reply to: The Plow Is Identified!!! posted by bill {Antique Acres} on January 18, 2000 at 13:36:26:
If you had one in 1925, what would you have used to pull it?
Post A Followup
: Re: Re: The Plow Is Identified!!!
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
