Rod and Main Bearings markings.
Posted by Tom Windsor on June 23, 2006 at 18:12:38 from (64.12.116.65):
"I thought" that one could look on the back side of the rod and main bearings and see if they are standard, 10 over or 20 over, so I looked and found the following text and numbers on 4 lines:
"c IH (the logo) 002
7 6 F 23
355268-R1
Made in USA"
Does anyone have any insight into how to interpret this? Standard?
Tom Windsor
