Re: Farmall M/U-6 Head # help
Posted by Dave Slater on June 23, 2006 at 18:14:37 from (205.188.116.133):
In Reply to: Farmall M/U-6 Head # help posted by MJF on June 23, 2006 at 14:44:38:
6943 is a replacement block # for a M. 5-18-W indicates head was cast May 18 1951.Can't help much with head unless you would happen to know the total valve steam length. Almost all of the heads for that engine started with the # 8 . Not positive but think you can rule out head # 8060 gasoline head because the suffix had avanced past DA by 51. That leaves low compression and maybe 8574 gas head. Looking at combustion chamber or valve length can tell if its gasoline or other head. Should be a date code on engine block also.
