No 4th or 5th in 350 U
Posted by Formerly PaMike on June 24, 2006 at 10:26:27 from (4.239.165.184):
I was driving our 350U in 3rd gear. I went to shift up to fourth and nothing. Try 5th, nothing. All the gears work except 4th and 5th. I pulled the shifter off and the 4th and 5th slider just slides around like it isnt attached to anything. Any idea? Think the fork broke? There isnt any grinding noises or anything like that...
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
