Re: Continuing with the 4 terminal regulator saga
Posted by Brownie 45 on June 24, 2006 at 13:24:05 from (207.177.82.20):
In Reply to: Continuing with the 4 terminal regulator saga on a posted by 55 50 on June 24, 2006 at 11:09:51:
To try the L terminal, connect a sealed beam headlight between the L terminal & ground while the engine is running with a voltmeter on the battery. See what the voltage does as you connect & disconnect the load.
