Re: New Wheel Problems
Posted by brainerd dave on June 24, 2006 at 21:03:04 from (67.133.88.190):
In Reply to: New Wheel Problems posted by MAGMAN on June 24, 2006 at 16:25:11:
You could try jacking up the back end, put it in neutral so you can spin the wheel slowly, tightening only a little at a time on each bolt until you get 'em tight. Worked for me.
