Re: 1961 Cub Drive Train
Posted by Janicholson on June 25, 2006 at 13:32:08 from (66.173.50.28):
In Reply to: 1961 Cub Drive Train posted by mimnpipd on June 24, 2006 at 20:16:51:
The engine may not be stuck, but you did not say it runs. If it is not running. Then you may not have let out the clutch with it running. The front bearing in the trans could be rusted, or self destructed. The counter shaft may also be on a bad bearing. Neither of these turn when in neutral. If you can hand crank the engine with the trans in neutral and the clutch out, it should be able to be pushed in neutral as well. (from your description)
If it will not turn by hand cranking in neutral, the top of the trans needs to come off. (my opinion) A service manual is mandatory before taking the top off.
JimN
