Re: 560 gas oil pressure relief valve
Posted by Janicholson on June 25, 2006 at 20:19:39 from (134.84.102.134):
In Reply to: 560 gas oil pressure relief valve posted by Rockytop 560 on June 25, 2006 at 11:42:42:
I've Had 3 hrs to think on this. I do not know where the valve is located. With that in mind, I would heat the material around the valve with a propane torch, moving the flame a lot to keep it even, Then I would use some (don't laugh) wart freezing product from the drug store to chill the spool. If it has a stub on the end, I would use a needle nosed visegrip to grab it and put some outward removing force on it. (it probably can't move any farther in because it is stuck in. Good luck, and let us know the outcome. JimN
