Re: timing a 436 motor
Posted by Sheepdog in NE on June 26, 2006 at 14:21:10 from (67.0.3.247):
In Reply to: Re: timing a 436 motor posted by Larry B. - 1466 on June 26, 2006 at 10:35:06:
Flywheel, right side of clutch housing, 2 1/4" bolts hold cover on. The pointer is under the cover. Numbers will be on the 10"s with marks in between. Turn fly wheel with small crow bar in ring gear teeth through the hole where cover was.
