Re: 1950 M ignition starting problem
Posted by John T on June 26, 2006 at 14:54:01 from (66.244.90.5):
In Reply to: Re: 1950 M ignition starting problem posted by RustyFarmall on June 26, 2006 at 12:34:28:
jpl n Rusty, If he happens to have one of those solenoids with the extra lil (I) terminal (like Ford n some GM used) its hot with full battery voltage ONLY when the solenoid is engaged (its cranking) and thats good for and used when one uses a 6 volt coil with an "External" Ballast Resistor on a 12 volt tractor. What it does is effectively by pass the ballast and apply full unballasted battery voltage to the coil (ie. 12 volts on a 6 volt coil) ONLY while cranking. Thats what some farmers call a "start on 12 and run on 6 coil system"........HOWEVER if theres no external ballast to by pass, the solenoids lil extra lil I terminal (or any other terminal for that matter) dosent apply any more voltage to the coil (assuming switch n all else is okay) then what normally comes from the regular ignition switch feed. HOWEVER if the switch contacts (resistive/carboned/loose) or the switch wiring is bad, the extra lil jumper wire to the coil could help and it cant hurt nuttin so its worth a try BUTTTT its not the normal or factor way, it is the factory way when they use a 6 volt coil on a 12 volt tractor with an external ballast and want to improve the starting spark energy and yessssss it works great. Bottom line is its NOT ordinary but it cant hurt and might actually help as a band aid approach (but he needs to fix the REAL problem) if the switch or wiring has some resistance and is dropping voltage. Fun chat, yall take care n God Bless John T
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
