Re: Super A exhaust manifold vs Carburetor linkage
Posted by Brownie 45 on June 26, 2006 at 17:56:01 from (207.177.82.247):
In Reply to: Super A exhaust manifold vs Carburetor linkage posted by BobCD on June 26, 2006 at 10:13:37:
If I remember correctly, the throttle rod[governor to carb] is the closest to the block of any part on the carb. Without going out to look, if you can possibly get the throttle rod ground off enough to fit next to the carb instead of next to the block, you might be able to clear . It would require a small offset to be bent in the throttle rod, so's it wouldn't bind.Another possibility would be to take a die grinder & enlarge the holes in the manifold "away" from the block. Someone will no doubt have a better idea, though.
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
