Re: Farmall M Water Pump
Posted by Haas on June 26, 2006 at 18:48:35 from (12.65.12.142):
In Reply to: Re: Farmall M Water Pump posted by Nebraska Kirk on June 25, 2006 at 18:58:53:
I suppose it might be easier to remove the pump than to remove the radiator. I have not done this on an M, but have on an I-6, which is easier because the steering shaft does not have to be removed like on the M and the bolster is not in the way. I've never had much luck trying to get to the fan area on these tractors without removing the radiator.
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition. ... [Read Article]
